ADDAC monster!
Moderators: Kent, __ag
mats_j
ADDAC monster!
Post by mats_j » Wed May 04, 2016 1:37 am
Just saw this on the website:
http://www.addacsystem.com/product/adda ... ster-frame
Seems very interesting to me — tall rather than wide, solid power and aesthetically pleasing. Anybody have one, or are they not available yet?
toothless_wonder
Post by toothless_wonder » Sat May 14, 2016 5:31 am
Yhaa Saw this as well , and I am searching for a new case , a big one. So this seems like a good candidate and reasonably priced !!!
My main concern is how good the addac bus boards are ?
Are the Outputs : +12V regulated,- 12 regulated, +5V regulated ?
Low Noise, high stability ?
Anyone ?
Bumply
Post by Bumply » Wed May 18, 2016 10:44 am
Curious as well. Will likely buy this, but would like to know about any experiences with ADDAC power.
I don’t know...
mats_j
Post by mats_j » Mon May 30, 2016 11:13 am
Had some communication with Addac, and it's 5000 mA on each rail. I'm guessing I would need (almost) double that :confused:
But they can accomodate any custom needs it seems.
Bumply
Post by Bumply » Tue Jun 07, 2016 1:26 pm
Just put in an order. They charged a bit more (170 euro I think) to bring it up to 10a +/-
I don’t know...
garrim
Post by garrim » Tue Jun 28, 2016 7:23 am
I'm eagerly waiting for mine.
And as I currently have a 9U/197hp with a total of 3600 mA. The ADDAC case will be more than enough for me.
May I ask what modules you have that puts the need for amps so incredible high up?
Kind regards
G
mats_j
Post by mats_j » Tue Jul 05, 2016 2:11 am
So this is my current rack:
https://www.modulargrid.net/e/racks/view/279741
As you can see it consumes 4020 mA on the +12V, with only 4 of the 7 rows of the monster case filled.
Ttrev2k
Post by Ttrev2k » Wed Aug 10, 2016 9:23 am
Bumply wrote:Just put in an order. They charged a bit more (170 euro I think) to bring it up to 10a +/-
Would love to know what you think once it's all set up? Also please share some pics :)
cybchris
Post by cybchris » Tue Aug 16, 2016 10:52 am
Ttrev2k wrote:Would love to know what you think once it's all set up? Also please share some pics :)
Below is an image of my recently-arrived Monster Frame, half loaded. To answer a few of the questions above:
- It's a hybrid switching-into-linear-regulator supply, with fairly large heat sinks on the linear regulators. I've not had the chance to thrash it and see how the modules behave, but everyone's powered up so far without issue.
- I too needed more power (for one, the eventual plan is for 6 Distings - 4 are mounted so far); I had the +12v capacity doubled to 10 amps. The extra price was very reasonable.
- The power supply does not normally supply +5v. I bought 6 of ADDAC's plug-in boards that add +5 (drawn from the +12 rail) locally to just that board.
- The ergonomics are really nice - the amount of curve was well thought out; the width to height ratio is comfortable. (I did have to order longer patch cables; a new batch is on its way from Black Market Modular...)
- The odd number of HP in the width is...odd. I only have a couple of modules that are an odd number of HP wide, so I'll be using some 1 HP and 3 HP blanks eventually.
- Does not ship with screws; have those handy. I used 3M x 8mm hex head bolts plus nylon washers. The threaded strips do not reach the full width of the case; each row is made up of 2-3 segments each - so it took a little bit of sliding and aligning initially when mounting modules, but then it went smoothly from there. The rails would be easy to remove and replace if you wanted to take out the threaded strips and go with sliding nuts instead.
- Shipping to the US was very reasonable, I thought - under $200. But the Monster Frame got beat up in shipping; I had to spend a few days making repairs. And my timing was such that Andre was on vacation when it arrived. But he sent a very helpful email today for my remaining issues. As a result, they will be changing their packing in the future. Also, mine - most likely because of the damage - had some flexing issues on the back panel in particular; I added a spine of aluminum angle which cured it.
hope that helps -
Chris
Learning Modular
http://learningmodular.com
http://bit.ly/LearnModular
80s synth designer back from a long sleep...
monads
Post by monads » Fri Sep 15, 2017 6:46 pm
Not mine...but pretty cool build up!!! 8-)
ADDAC System
Post by ADDAC System » Sat Sep 16, 2017 6:44 am
Building up a system from scratch is always an exciting time :love:
monads
Post by monads » Thu Dec 28, 2017 10:54 pm
Well....details below on my 901M 21U and ADDAC Experience:
- The case is well designed & solid. The cut openings on the side-panels are nice for handling the case as well as routing cabling to the back of modules if necessary (i.e. nw2s::io). The length (1meter wide) of the case is perfect and the odd HP isn’t an issue due to plenty of eurorack module configurations. Power is provided via one cable connected to the case and the 2 LEDS located on the front of the case for power status is a welcomed feature.
- I added additional 5A to each rail for a total of 15A on ±12V rails (not shared). This actually turned out to be more than enough power and I probably would’ve been fine with the now standard 10A for each rail.
- I added 6 of ADDAC’s bus boards w/5V adapters. You don’t really need to upgrade the ENTIRE case with all the bus boards/5V adapters if you strategically place the boards & your modules requiring so. I do recommend a minimum of 6. I had mine installed on rows 3, 5, 7 (from bottom to top).
- I added the 200A Ammeter (highly recommended) since it measures the current draw in the system. It’s an excellent module and a no brainer for case of this size. ADDAC will ask what row you want it installed and the top (left) or bottom (left) rows are best for visibility but you can place anywhere you want. Take note because you won’t want to move it once installed.
- I added the frame shelf system 901MS. This ships separately (separate shipping charges) from the case. It’s easy to install and is great for setting small items on top of. If there’s one small thing I would change it’s the very top hardware screws ADDAC provided (2 for each side) for securing the top shelf (I didn’t use the ones provided since they wouldn’t have set flush when drilled). I suggest you obtain/use your own (going to advise ADDAC to supply a different set).
- The quoted shipping cost to the USA (greater L.A. area) was reasonable at 320euro ($377). The packaging was excellent and the case arrived safely/undamaged via USPS in a special delivery truck! Keep in mind lead times (2mos) from order placement/payment to delivery. Make sure someone is around to accept delivery as you will likely have to sign for the package and it’s not something you can simply go and pick up at the post office unless you have a vehicle to accommodate. I’m not sure if ADDAC offers other expedited delivery services (i.e UPS, FedEx, DHL, etc.) but be careful if yes and you choose because you will probably get hit with a separate bill for import/customs duties & fees.
- Closing comments, it’s one of the BEST ‘large’ eurorack cases available from a manufacture. The costs are reasonable and you have options to customize the case to your specifications. Filipe & Andre from ADDAC were AWESOME and helpful in communications from order placement through delivery. The only drawback is that after you’ve set-up and racked your modules you might want another 21 or 15U!! 8-)
Summa
Post by Summa » Fri Dec 29, 2017 7:23 pm
monads I spy an 807 mixer!!!
:loves: :goldfish: :w00t:
ADDAC System
Post by ADDAC System » Mon Jan 01, 2018 2:05 pm
:love: :love: :love: :love: :love: :love: :love: :love: :love:
Xtheunknown
Post by Xtheunknown » Wed Feb 13, 2019 1:59 pm
monads wrote:Well....details below on my 901M 21U and ADDAC Experience:
I am considering one of these. What was the total cost with the extra power, 5V power, ammeter, shipping, etc.?
monads
Post by monads » Wed Feb 13, 2019 4:44 pm
If you want the exact same setup as mine...with shipping it'll run you around 2382€ ($2,683). If you don't want the shelve system you can back out 300€ (includes shipping estimate), nor extra power another 170€ from the above.
zengomi
Post by zengomi » Sat Mar 09, 2019 7:07 pm
Arrival!
monads
Post by monads » Mon Mar 11, 2019 8:30 pm
Nice!!! Now let's get it setup :party:
solipsvs
Post by solipsvs » Wed Mar 20, 2019 10:54 pm
monads wrote:Not mine...but pretty cool build up!!! 8-)
think he had it planned out before he executed? the longer i do this the more clear my module placement and setup is but keeping it simple as much as possible is the rule of that rules my book.. a system like that must have a nice sound and variety. who needs real gear? haha
soundslikejoe
Re: ADDAC monster!
Post by soundslikejoe » Mon Nov 16, 2020 9:54 pm
I've had an ADDAC Monster for more than a year now. Solid case. Very nice in almost every respect... with one caveat.
PSU... I noticed from day one that certain modules misbehaved. Koma Poltergeist for instance would power up with random solo or mutes active. Didn't do that before. Etc. Recently, I've done more studio recording and sound design. Under the RX microscope, I would find strange noise patterns in my sounds. Closer inspection finds that all my digital modules emit a noise floor.... in some instances, it's intense. Tasty Chips ECR1 was especially noisy. Same with e520, Disting EX, and etc. I'm currently experimenting with LIBB passive bus boards. Hope installing these help lower that noise floor on digital modules.
Anyone else experience noise floor in this design? Tried other bus boards? Can anyone explain why ADDAC have ground wires inserted into the +12v and -12V outputs of each PSU? It's like one is only supplying +12v and the other PSU is only -12v and they wired the unused outputs to ground.
Return to “ADDAC System”
