Korg SQ-64
joeSeggiola
Re: Korg SQ-64
Post by joeSeggiola » Mon May 03, 2021 8:45 am
kinkujin wrote:
Mon May 03, 2021 8:11 am
It seems that issues are being ironed out with firmware, eh?
Not really. They fixed the biggest issue (tracks synchronization in PATTERN mode) recently. Some (eg. SonicState) says it's not really 100% fixed, but I didn't manage to reproduce the issue anymore... The rest of bugs described in this thread, and especially the obvious missing features (eg. automatic tempo-quantization, transposition with external keyboard, etc) are still there, and we have no news of incoming updates. For me that's not a deal-breaker, but if these features are essential for you (check the thread for a complete list) I suggest you to wait for an actual fix...
kinkujin
Re: Korg SQ-64
Post by kinkujin » Mon May 03, 2021 8:49 am
Ugh. Thanks Joe. I guess I wait some more.
Ishkash
Re: Korg SQ-64
Post by Ishkash » Tue May 04, 2021 4:54 pm
OK, now Anderton's UK has updated its new ship date to the start of June! Which means I guess I can expect the same here in the US... :doh:
To any of you wigglers in the above areas or beyond...where did/are you scoring yours?
I'm just aching to start with it! The more I learn about it, the more I believe I will be a very happy customer.
EDIT: I appear to have struck gold. Quick, Western wigglers, quick!!! Pitbull Electronics in National City, CA are stocking 5 Korg SQ-64s. Actually, 4 as of just a minute ago. The company's tech support confirmed that the units are in stock and ready to ship.
electricfence
Re: Korg SQ-64
Post by electricfence » Tue May 04, 2021 4:59 pm
My Sweetwater rep suggested that they will be receiving a shipment any day now. I think I preordered in February. Maybe try there.
Guillem
Re: Korg SQ-64
Post by Guillem » Wed May 05, 2021 6:10 am
Guillem wrote:
Mon May 03, 2021 4:36 am
Hello,
I have a problem, I would like to be able to play in real time, but this option is only possible if SQ-64 is in STOP in keyboard mode, the idea would be to be able to play in real time on the other tracks without having to record the sequence.
Any ideas?
I found the answer.
In global settings, (a13) keyboard behavior, override (by default is setting in transpose mode)
onlyHzwhenI...
Re: Korg SQ-64
Post by onlyHzwhenI... » Sat May 08, 2021 6:20 pm
joeSeggiola wrote:
Mon May 03, 2021 7:06 am
Arnie wrote:
Sun May 02, 2021 12:42 pm
Does 2 midi-outs mean you can connect only 2 midi-instruments, such as Volcas? Or can you connect more using different midi channels?
If your instruments have MIDI Thru ports, you can chain them and just use different MIDI channels for each one of them (SQ-64 is easy to configure for this use case). This way the instruments will respond to their MIDI channel and pass the rest along the MIDI Thru port for the other ones.
Edit: and yes, if more than two of your instruments does not have MIDI Thru, you'll need a MIDI router or splitter box, as Headphones73 said.
Anybody know if the 3.5mm TRS midi from the SQ-64 can be split passively by using a TRS --> multi-TRS headphone splitter, then fed to several hungry Volcas via several type A midi dongles?
Last edited by onlyHzwhenI... on Sat May 08, 2021 9:12 pm, edited 1 time in total.
Ishkash
Re: Korg SQ-64
Post by Ishkash » Sat May 08, 2021 7:39 pm
It's a marvelous bit of gear. I love it. I'm using it via USB-MIDI for now, to learn the basics and set up DAW interconnection, before I inject its brainpower into the modular. That will surely be a jaw-droppingly happy day.
It can be a bit confusing, even maddening, at first. The manual is indeed long on reference but woefully short on practical tutorial. It is almost as if Korg is pushing this towards more advanced users, that notion reinforced by a UX that is highly sophisticated, if a bit inaccessible. Yet...the price point is SO accessible! Hats off to them for raising the bar in that regard (IMO).
It's smaller than I thought (in a good way). Solid though, like a little bulldog. Damn sexy (IMO).
I've got serial # 000917. That's a lot of zeroes (though I realize one can't always tell how these serials are coded). I believe Korg is looking to make a sizable mark with this one, and I do anticipate significant firmware upgrades over the next 5 years.
I could be disappointed in that regard. But for now I'm very happy.
+1!
behndy
Re: Korg SQ-64
Post by behndy » Tue May 11, 2021 1:04 pm
hurm. was batting back and forth about canceling my order and.... Control just sent a shipped email.
i have huge lusts for the No Announced Date Korg drum machine coming up, curious about the SQ with that.
Ishkash
Re: Korg SQ-64
Post by Ishkash » Tue May 11, 2021 7:47 pm
Is anybody else having trouble pitch-sequencing their CV gear? I'm using Track A to juice my Minitaur...gate is transmitting fine...but pitch seems hopelessly bugged. I can't figure out if I'm missing something in config, or have encountered a MADDENING bug...
I'm pretty sure the problem is not on my Minitaur's end, since I am still able to "play" it from a MIDI keyboard, with pitch intact.
But the SQ's pitch sequencer is being shady as hell. Changing step pitch...basically does nothing? It was working for a few minutes when I started...sort of.
But now, changing pitch seems to do nothing. At all. Its super erratic. It's only playing back two notes...I believe they're D1, alternated with the Minitaur's highest note (C5). Or something along those lines.
Using the "Test Output" function" also only gives me the same two notes.
WTF?
I noticed that calibrating for +1V & +4V in the Minitaur Editor fixes the problem. But as soon as I reset the SQ-64...pitch control is gone...and I'm back just two notes.
As Walter once said to Donnie...I'm out of my element. Perhaps one of you higher-level wigglers has a clue what's going on here.
EDIT: I don't seem to have this problem in USB-MIDI mode. Only when using the analog outs. They just don't appear to work (on the pitch channel). I feel like I may have heard about this problem in one of the early review videos, though I can't remember which (edit: nah, this is different). Definitely maddening...unless I am missing something (and I hope I am).
Richard deHove
Re: Korg SQ-64
Post by Richard deHove » Tue May 11, 2021 8:05 pm
Have you set the correct voltage value for the CV pitch track output? (Page 20 in the manual) Or at least tried changing it to see if it makes any difference.
Ishkash
Re: Korg SQ-64
Post by Ishkash » Tue May 11, 2021 8:18 pm
Thanks for your response, Richard. Looping back to the manual as you mentioned, are you referring to the voltage bias setting, or the reference note setting? Adjusting the voltage bias seems not to make the slightest difference to anything. Adjusting the "reference note" (and I still don't even know exactly what that refers to) also doesn't seem to remedy anything at all. At one point, I noticed that setting the reference note to C5 (the highest playable pitch on the Minitaur) seemed to unlock the full range of notes. But I still don't know how that works or what it refers to. Either way, neither setting seems to address the issue. It's almost as if the pitch CV out is totally broken.
pmboos
Re: Korg SQ-64
Post by pmboos » Tue May 11, 2021 8:21 pm
There is a new Korg Drum Machine coming out?
“What actions can be taken to create a joyful, inspiring, and productive work environment?"
