PEQ
Moderators: Kent, BugBrand
tIB
Stainer!
Post by tIB » Sat Mar 01, 2014 4:30 pm
:party:
numan7
the most autistic amongst us
Post by numan7 » Sat Mar 01, 2014 4:39 pm
:tu: hoo-ray!!
cheers
otoskope
Post by otoskope » Sat Mar 01, 2014 4:43 pm
Changes so small that it can form a stereo pair with the previous version, or do I need to buy two new ones? :hmm:
The brain is always greener on the other side.
soundcloud1 soundcloud2
bandcamp
youtube
BugBrand
Knowledge of Bugs
Post by BugBrand » Mon Mar 03, 2014 4:46 am
I want to try (on a proto, coming shortly) just a small change that may widen the Q range slightly (per mid band). That's the only possible change in sonic terms, I think - so may not implement it to keep consistent with the old ones.
Will also be changing:
- bypass as toggle switch rather than push
- output will be impedance balanced for improved CMRR when feeding to balanced inputs.
- DC-DC will now be off-board like other 'modules'.
So, basically, should be the same..
indexofmetals
Post by indexofmetals » Mon Mar 10, 2014 6:22 am
good news Tom, I'll take quite a few. I need to find someway to house them all together, plus a chained power supply
soup
Post by soup » Fri Mar 14, 2014 1:35 pm
BugBrand wrote:I want to try (on a proto, coming shortly) just a small change that may widen the Q range slightly (per mid band).
I don't know if this means narrower Q but if so yes please.
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed May 21, 2014 5:45 am
Bump to announce the new V2 release today!
In the meantime I bring back something of a slow-burn secret - the PEQ Parametric EQ, updated to Version2.
I did 50 of the original PEQ back at the start of 2013 and they've found great favour for sonic processing.
The changes in this version can be seen as a few tweaks to the frequency response along with some structural alterations based on my ongoing learnings:
- Input & Output circuitry updated, including changing the Output to being Impedance Balanced (some background reading: http://www.uneeda-audio.com/zbal.htm)
- Low-Cut filter revised to improve response and widen frequency range
- the three State-Variable Filters (Low/Mid/High-bands) have improved control response along with improved Q range - now wider at the one end and narrower at the other.
- bypass now uses a Toggle Switch
Hopefully the run of boards for these will last a while - 18 are completed for release today, with more to follow: http://bugbrand.co.uk/shop
soup
Post by soup » Wed May 21, 2014 12:55 pm
How much narrower is the Q?
Is it noticeable versus the OG version?
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed May 21, 2014 2:59 pm
Theory said a change of 1/2 octave to 1/3 - but I should try to do a new demo actually.
Cheradenine
Modulate me harder
Post by Cheradenine » Fri May 23, 2014 6:53 am
Ordered !
:nana: :banana: :nana:
ear ear
Post by ear ear » Mon May 26, 2014 1:37 pm
Cheradenine wrote:Ordered !
Same here! Very excited. :party: :hyper: :goo:
He throws the ink first and works out what it is later. "I've got to turn that into parrots." - Ralph Steadman
BugBrand
Knowledge of Bugs
Post by BugBrand » Tue May 27, 2014 10:01 am
A pair of PEQ-pairs!
Joined-at-the-hip.
(single DC input too)
soup
Post by soup » Tue May 27, 2014 12:03 pm
:bacon::bacon:
indexofmetals
Post by indexofmetals » Tue May 27, 2014 2:07 pm
so you did it!
vasculator
Post by vasculator » Tue Jul 01, 2014 11:01 am
Bugged Endcaps. I absolutely love the PEQ and had to order another so there is one for each Elektron.
Image[/img]
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed Jul 02, 2014 8:42 am
Thumbsup!
Paranormal Patroler
Post by Paranormal Patroler » Wed Sep 10, 2014 7:55 pm
So you guys reckon these would stand well as a stereo EQ right at the end of the audio chain? I'm thinking it could compliment my live setup nicely. And they look cute to boot.
BugBrand
Knowledge of Bugs
Post by BugBrand » Thu Sep 11, 2014 5:15 am
Well, I did make myself & a couple of other guys some co-joined pairs with stereo work in mind. Certainly works well, though my feeling for ideal would be that I'd much rather have the Low/High cut controls properly tied in stereo (ie. one knob to control left & right together)
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed Feb 11, 2015 4:25 am
The final batch of PEQs for now went on sale yesterday -- that's the end of this run of circuit boards, so it'll be later this year before more can be done..
cleahy
Post by cleahy » Wed Feb 11, 2015 5:14 am
Just bagged one - woo!
dogoftears
Puddle of Sealions
Post by dogoftears » Wed Feb 11, 2015 1:19 pm
BugBrand wrote:Image
basically it works but yeah no two PEQ's are perfectly matched, so settings are slightly different on the right and left side for stereo work. this is fine for the studio cus i can just balance each side with a test oscillator and digital meters, any time i've used it live i always take a bunch of photo's of my settings for recall.
this is normal by the way-- if you give a knob say +/- 15 dB of gain there is no way to control where each value in btwn will fall on the knobs swing. the only way around this is rotary switch knobs which of course adds significantly to cost (and QC/testing!)....
if the controls were ganged using a single pot i suppose this also solves the issue? but then you lose the ability to have two mono PEQ's. so yeah, the give n the take.
music and mastering: http://xexify.com
BugBrand
Knowledge of Bugs
Post by BugBrand » Wed Feb 11, 2015 2:10 pm
dogoftears wrote:basically it works but yeah no two PEQ's are perfectly matched, so settings are slightly different on the right and left side for stereo work. this is fine for the studio cus i can just balance each side with a test oscillator and digital meters, any time i've used it live i always take a bunch of photo's of my settings for recall.
The stereo approach would likely be Voltage Controlled - not only for potential CV fun, but mainly so that you could properly avoid the issues you mention.
richard
bananaphile
Post by richard » Wed Feb 11, 2015 2:23 pm
I have been using my pair for mastering. Sonically I think they really do cut it but controlwise obviously not really... no clear matching or repeatability. Fortunately nothing I have mastered using them has come back for a retweak yet!
All in all a very impressive bit of kit, its very hard to imagine what else could come near at the price as well. But stepped controls, selectable ganging and balanced inputs would send this into the next dimension. For me the extra cost would definitely be worth it.
Bastard Science Vol.1 and 2 (Hordik, Buchla, Serge, EMS, Oberheim) https://soundanatomy.bandcamp.com/album ... ence-vol-1
https://soundanatomy.bandcamp.com/album ... ence-vol-2
Tales from the Voodoo Box (EMS Synthi A solos) https://soundanatomy.bandcamp.com/album ... ynthesiser
Richard Scott - Several Circles https://cuspeditions.bandcamp.com/album ... al-circles
dogoftears
Puddle of Sealions
Post by dogoftears » Wed Feb 11, 2015 2:48 pm
richard wrote:I have been using my pair for mastering. Sonically I think they really do cut it but controlwise obviously not really... no clear matching or repeatability. Fortunately nothing I have mastered using them has come back for a retweak yet!
glad to hear yr also mastering stuff with it richard. some how it really does work just like some of the 20x more expensive counter parts. i've found you can get the PEQs to match pretty good with a test osc. just set it with your ears, then go thru each band and approximate the frequency on a test oscillator, and match the gain for each side. it's not 100% perfect but should get you within .5 dB matching... actually i can get em pretty near perfect... it sounds arduous but after doing it a bunch it only takes me about a minute now.
honestly stepped controls/linking options etc would take it into the realm of being an "official" mastering EQ and even if the price were 3x it would still be justified. mastering EQ's are friggin *expensive*!!
vasculator
Post by vasculator » Wed Feb 11, 2015 3:15 pm
my pair of PEQs is pretty much indispensable. i would leap on a stereo version.
Return to “BugBrand Devices”
