Oops My Cable -- How to mend a banana (cable)
Moderators: Kent, BugBrand
BugBrand
Knowledge of Bugs
Post by BugBrand » Mon Jan 10, 2011 6:46 am
Sometimes the wire comes out of the banana plug - argh!
But it is quick and easy to repair!
Tools required - one small flathead screwdriver and a pair of wire-strippers
You will notice two little rectangular holes on the side - use the screwdriver to depress these nubs and flip out the top part.
You can then slide out the metal part.
Inside the metal part is a little threaded set-screw - you can see it through the side window (where the wire will go). Put the screwdriver into the top of the metal part and locate the screw terminal. Unscrew it to open up the side hole.
Use the wire strippers to strip a short length on the end of the wire, then insert it into the side-hole.
Tighten to attach. Trim off any excess from the other side of the side hole.
Re-insert the metal part and close the little plastic flap.
Job Done!
miditerranean
Post by miditerranean » Mon Jan 10, 2011 4:32 pm
Hasn't happened to me yet but I'm saving this thread for future reference, thanks Tom!
emergencyofstate
Synthesist
Post by emergencyofstate » Sun Jan 23, 2011 10:20 pm
Thanks for this Tom. I just repaired three of my cables and it took less than 10 minutes!
lud
Post by lud » Wed Feb 14, 2018 2:20 pm
Thanks a lot for this handy little post, didn't realise it was so easy and solder-free to put together a Rapid banana cable :nana: :banana: :bananaguitar:
Flexyflier
Post by Flexyflier » Fri Dec 07, 2018 10:45 pm
had a Phenol,that was my banana plug experience,but going to order some cables from Tom
I also have a makenoise jumbler and one from Tony at Synovatron......Euro to banana.
http://synovatron.blogspot.com
"Drowning...................not waving!"
Kafgee
Post by Kafgee » Sun Jan 13, 2019 8:59 pm
What do you do when just the tip comes off ?
BugBrand
Knowledge of Bugs
Post by BugBrand » Mon Jan 14, 2019 2:30 am
Do you mean the little round tip - c. 3mm long piece right on the end?
If so, unfortunately I think the whole end should be replaced.
castano
Post by castano » Sun Jun 09, 2019 3:06 pm
Does anyone know where I can order those banana plug ends to make my own cables?
lud
Post by lud » Sun Jun 09, 2019 3:27 pm
You can get the 4mm plugs and wire in different colours at Rapid electronics online :banana:
castano
Post by castano » Thu Jun 13, 2019 4:56 pm
Thanks for the info! :)
Return to “BugBrand Devices”
