4U VCA ecology today
kevin0
Post by kevin0 » Sat May 01, 2021 4:48 am
Hello all,
I am looking to expand on my 73-75 homebuilt and I am curious about dedicated VCAs in 4u. The following is a tentative list of the VCAs in the wild:
Serge designs:
-R6 Gate (On early Serge panels, PCBs formerly sold by Elby, on the 73-75 panels, PCBs might be sold by Prism.EOC in future?)
-Xfaders (STS, R*S)
-Dual VCA (STS)
-Universal Equal Power Audio Processor (STS, PCBs formerly sold by Elby)
-Active Processor (STS, R*S)
-Serge VCM (top Section)
-Dual Channel Stereo Mixer (R*S, CGS)
-Multi Channel Stereo Mixer (CGS)
Designs by others:
-Clee Quad VCA
-VCAs on the Ugly Sound / Ian Fritz panels.
-Stroh FadeX
-Stroh Dual Pico VCA
-Slightly Nasty’s Multiband filter has a VCA on it
-CGS 64 / 364
-Metasonix Bellend
-Hollasynth 4 Channel Scanning / Quad VCA
LPGs:
Clee VC Resonant Gate
Thomas White Dual LPG
Metasonix RK5
Random Source Donks
Have I forgotten any? My only experience is with the R6 Gate on the THC 73-75 panels and I think it sounds super!
What are people’s favourites? Do you use different VCAs for different applications?
Do people use the VCAs on the DCSM / MCSM just to set the levels rather than feed envelopes into the VC Gain? It seems like an attenuator on the VC Gain input would go a long way here...
Is the active processor the only DC-coupled VCA on STS/R*S panels? What do DIYers use for DC VCAs?
batchas
Re: 4U VCA ecology today
Post by batchas » Sat May 01, 2021 6:13 am
Stroh Dual PICO VCA.
finlayshakespeare
Post by finlayshakespeare » Sat May 01, 2021 6:16 am
I’m gonna do a discrete VCA design for a forthcoming BPoOT panel ;)
kevin0
Post by kevin0 » Sat May 01, 2021 6:22 am
Exciting! Discrete to avoid using CA3080?
finlayshakespeare
Post by finlayshakespeare » Sat May 01, 2021 6:25 am
Ah no! Just a transistor based design that’s nice and easy to make work. We used it at FSS in the Stumm module. It can also be nicely overdriven
kevin0
Post by kevin0 » Sat May 01, 2021 6:41 am
Ah okay! Did I read that you're designing this panel to complement the 73-75 Homebuilt?
finlayshakespeare
Post by finlayshakespeare » Sat May 01, 2021 7:05 am
Ish... it’s all gotten a bit out of hand in all honesty. Expect a relatively full system from BPoOT in the next couple of years ;)
oldenjon
Post by oldenjon » Sat May 01, 2021 8:29 am
There is also the HollaSynth 4 Channel Scanning / Quad VCA
listentoaheartbeat
Post by listentoaheartbeat » Sat May 01, 2021 8:34 am
How about VCM top section, and the New Ring (R*S)?
johnchantler
Post by johnchantler » Sat May 01, 2021 11:37 am
I have one of these L-1 quad VCAs behind a LW panel: http://l-1.su/QuadVCA.html
bwhittington
Terrifying Brain Secret
Post by bwhittington » Sat May 01, 2021 12:07 pm
cygmu
Post by cygmu » Sat May 01, 2021 3:15 pm
So there is, heh. I will stay away from self-promotion as far as possible but for information it consists of 4 x linear VCAs (lm13700 based) plus a 4-way crossfading function.
NeolithicElectrophones
Post by NeolithicElectrophones » Sat May 01, 2021 3:44 pm
My favorite VCA in any format I've used. Very easy to dial in, solid and clean sounding, very ergonomic layout even when patched. It's the main hub of my LW setup. Also, a real pleasure to build with a great PCB layout to boot!
Nisse_D
Post by Nisse_D » Sun May 02, 2021 3:21 am
+1 for the Scanner; great sounding and very straightforward build - no hard to get components and no wiring if you use the LW panel. Agree was a pleasure to build!
kevin0
Post by kevin0 » Sun May 02, 2021 3:57 am
Lot of great options I did not know about! Still curious about a couple of points though:
-Do people have favourites for particular purposes? (i.e. percussive sounds, gritty sounds, clean sounds etc)
-Do people use the MCSM/DCSM for enveloping sounds or just setting the output level?
-What do people use for DC signals?
mfaraday
Post by mfaraday » Sun May 02, 2021 9:12 am
the R6 gate has both AC and DC inputs - that flexibility makes it easily one of my favorites. along with separate log and linear control inputs, it is a hell of a lot of fun
really keen to have a panel with like a bunch of R6 gates and rings and an R2 dual mixer or something
kevin0
Post by kevin0 » Sun May 02, 2021 9:52 am
The R6 does seem pretty special. I love feeding a log envelope into the log input to get an exceptionally dramatic swell. Very gritty!
syncretism
Post by syncretism » Sun May 02, 2021 10:53 am
Stroh has a new, dual VCA with manual offsets.
Xomrys
Post by Xomrys » Sun May 02, 2021 2:44 pm
I absolutely depend on the '73 VCA, due to separate DC/AC inputs, the convenient inverted LIN input, small footprint and general sound quality. Sometimes it is useful just to gain stage, meaning without CV controls, when I run out of mixers.
kevin0
Post by kevin0 » Mon May 03, 2021 3:24 am
That sounds interesting! Manual offsets meaning there is a gain knob and an attenuator for VC gain? Or something else?
What version of R6 are you using? Original paperface? CGS? THC? I understand that the CGS version can be built with either LM3700 or CA3080 and I've always been curious about the difference.
Prunesquallor
Post by Prunesquallor » Mon May 03, 2021 4:32 am
There's also Mutable Instruments Blinds in a LW panel, and I'm pretty sure Charlie made the L-1 Quad VCA for himself. I don't really see the point of listing these third-party VCAs, though. If it's DIY then it can be put behind a panel. Should the list stick to VCAs designed by 4U guys, Serge, Clee, Stroh, Fritz, etc? And where do ring mods and LPGs fit into this?
RIP Ziggy, the companion in my avatar.
Xomrys
Post by Xomrys » Mon May 03, 2021 8:16 pm
Original paperface. It's strange given how versatile this module is and how well it sounds, why they went away from this design, integrating VCA functionality into the mixers and UAP/UPAP which are more audio-focused.
qwoned
Post by qwoned » Tue May 04, 2021 12:44 am
I feel like a lot of the R series modules are much more versatile than their successors
syncretism
Post by syncretism » Tue May 04, 2021 11:33 am
Yep, just a knob for each, setting initial gain. Any CV requires processing elsewhere.
ashleym
Post by ashleym » Tue May 04, 2021 11:56 am
Sounds very exciting. Could i suggest just 0.5mm or so thicker panel please? I aim to have an instruments for a long time, nearly 40 years with my first- an SH101. Not everyone is like me so please make your own decisions..... :stardance:
