ENV-310 6HP adsr SMD by FEEDBACK [UPDATE!]
strat-1
Post by strat-1 »
www.feedbackmodules.com
[UPDATE] I uploaded new BOM and Build Manual.
A builder pointed to me, the switch is wrong in BOM. It should be ON-OFF-ON switch instead of ON-ON.
Deeply sorry for this mistake!
MAIN PCB Top and Bottom
POWER PCB Top and Bottom
This is an envelope generator based on the SMD AS3310.
The AS3310 is a modern recreation of the classic Curtis CEM3310 chip, used in many famous mono and poly analogue synth from the eighties.
We took the best ideas from all the classic 3310 circuits and tried to squeeze the maximum from this fantastic chip.
The MODE switch takes this module beyond a simple ADSR type envelope generator.
It can work as:
- NORMAL - a conventional ADSR envelope,
- DAMPED - an ADRR piano envelope approximation
- AUTO - a short gate will cycle the envelope shaper through a complete ADR envelope
It has an additional TRIGGER input which can be used for generating multiple peak envelopes.
This is a relatively easy build, using common parts and SO-16 AS3310 SMD chip.
Attack Time 2.5ms-1.5s
Decay Time 6ms-4s
Sustain Level 0-10V
Release Time 6ms-4s
ENV-100 is available in two type of kits :
KIT1 :
- 2 x PCBs + Front Panel
KIT2 :
- 1 x Red LED superbright
- 1 x AS3310 SMD
KIT3:
- 1 x AS3310 SMD
- 1 x Tactile E-Switch + White cap
- 1 x 100KB Pot
- 3 x 1MA Pot
- 4 x Minijack sockets
- 1 x 6way Pinheader Male for 10/12mm spacer
- 1 x 6way Pinheader Female for 10/12mm spacer
- 4 x 1900h Cream Knobs
The rest of the parts like resistors, caps, diodes, are easy to be found on every common store.
ENV-310 Build Files 1.0.zip
(33.86 MiB) Downloaded 19 times
ENV-310 - POWER pcb.jpg (110.48 KiB) Viewed 953 times
ENV-310 - Module.jpg (142.26 KiB) Viewed 953 times
ENV-310 - MAIN pcb.jpg (195.69 KiB) Viewed 953 times
ENV-310 Build Photos 1.0.zip
(11.03 MiB) Downloaded 28 times
strat-1
Re: ENV-310 6HP adsr by FEEDBACK [NEW SMD project!]
Post by strat-1 »
I made a movie demo for ENV-310.
ENV-310 fed into LO-FUSIONs freq input and cv input of VCA-100. In second part of the movie LFO-10 triangle output it's modulating the other freq input of LO-FUSION VCF. Signal source is the square output of TWO59 VCO.
Ambience is made with 1-BIT sigma delta DELAY.
VCA-100 is not in the system, is a work in progress module made on a testboard, soon to be released.
strat-1
Post by strat-1 »
I made a pdf manual explaining the functions of ENV-310 adsr.
strat-1
Post by strat-1 »
[UPDATE] I corrected some mistakes in the BOM list. The quantity for diodes was wrong.
strat-1
Re: ENV-310 6HP adsr SMD by FEEDBACK [UPDATE!]
Post by strat-1 »
Here are the time specifications:
Decay Time 6ms-4s
Sustain Level 0-10V
Release Time 6ms-4s
strat-1
Post by strat-1 »
strat-1
Post by strat-1 »
New video for ENV-310/ENV-100/LFO10 by COLOR MY SOUND :)
rithma
Post by rithma »
HEY STRAT!!!!!
What is the value for R9, marked "DNF"? Do not fill?
/Etienne
