Updated SSI2130 VCO Datasheet available...
lickspittle
Post by lickspittle » Mon Aug 03, 2020 9:54 am
...at the redesigned SSI site - http://www.soundsemiconductor.com/index.html
J3RK
Re: Updated SSI2130 VCO Datasheet available...
Post by J3RK » Mon Aug 03, 2020 11:12 am
Nice! Thanks for posting this. I hadn't checked in a little bit. Looks like they updated their site too. :goo: :party:
The TZFM comparator circuit looks simple enough. I really want to buy some of these.
J3RK
Post by J3RK » Mon Aug 03, 2020 11:23 am
I'm wondering if something like this: https://plastronics.com/catalog/standard-qfn-clamshell/ is available for purchase anywhere. Going to search around. Might be nice for prototyping or DIY with these QFN ICs.
lickspittle
Post by lickspittle » Mon Aug 03, 2020 11:58 am
...I really want to buy some of these.
Me too. Looks like a really well thought out design. I'm delighted that it has hard sync (this wasn't obvious in the preliminary datasheet).
adam
Post by adam » Tue Aug 04, 2020 2:24 am
all manner of qfn soldering videos on youtube, saw one with someone using a home etched pcb with no solder mask, looks like there's one technique where you hold the iron against the underside of the pcb to melt the solder on the central pad (pcb was designed with no copper or mask under that part by the looks)
neil.johnson
Post by neil.johnson » Tue Aug 04, 2020 5:13 am
The through-zero phase modulation sounds really sweet :tu:
Neil
Random ramblings :: http://www.njohnson.co.uk
SSI parts and more :: https://www.cesyg.co.uk
lickspittle
Post by lickspittle » Tue Aug 04, 2020 9:15 am
Neil,
Is the linear fm input DC coupled? I.e. is linear detune possible?
neil.johnson
Post by neil.johnson » Tue Aug 04, 2020 4:56 pm
Neil,
Yes it is. Linear detune is definitely possible in both plain VCO mode (just push more current into the LIN input but don't go negative) and in TZFM operation.
Neil
lickspittle
Post by lickspittle » Tue Aug 04, 2020 5:49 pm
Thanks Neil, this does look very impressive.
J3RK
Post by J3RK » Tue Aug 04, 2020 6:38 pm
A friend of mine gave me some tips on this, but also said it may not be worth the effort. I mean, might as well just order 50-100 chicklet adapters from a pick and place shop with the IC already on them. :party:
adam
Post by adam » Wed Aug 05, 2020 1:50 am
ssi are making an evaluation board for $50 with the IC already installed (you have to source & solder all the TH parts)
cygmu
Post by cygmu » Wed Aug 05, 2020 3:55 am
FWIW I find hand-soldering QFNs with an iron pretty straightforward, certainly easier than the TQFN packages that one finds for STM32 parts on many digital modules. The danger of creating a bridge is very low so once you have the part lined up properly it is pretty plain sailing. Board layout might make a difference, and of course you need the package to be the type where the pads extend up the sides. That does seem to be the case for the SSI2130.
TechNinja69
1-Post Wiggler
Post by TechNinja69 » Wed Aug 19, 2020 2:55 pm
That's what I've been told by the company. They are available right now you just have to contact the sales@soundsemiconductor. Their customer service is amazing and I even have a PDF on the board its self. It basically shows everything you can do with it and they give you a Digikey spreadsheet so you can source all the parts. Contact them if you're interested. I did.
Sadly their chips are not available at the moment. They are a couple of weeks before they release it though. So keep an eye out for when they come out!
adam
Post by adam » Thu Aug 20, 2020 2:22 am
ericneilj
Post by ericneilj » Thu Sep 17, 2020 4:03 pm
Anyone aware of retailers planning to sell these in small quantities?
forestcaver
Post by forestcaver » Fri Sep 18, 2020 5:27 pm
Looks like they are for sale now. Anyone done an eagle part yet? If not, I’ll do one over the weekend...
Oops “awaiting stock” :-(
adam
Post by adam » Fri Sep 18, 2020 5:50 pm
someone isn't looking very hard...
brycecake
Post by brycecake » Fri Sep 18, 2020 6:16 pm
I'm wondering if these are / will be available in the US?
forestcaver
Post by forestcaver » Sat Sep 19, 2020 3:09 am
Huh? I cant see stock at any of the uk stockists. Do you have them? Your website says it does not have stock and neither does cesyg. I dont buy based on preorder.
Or do you mean the eagle part? (Your post isnt very informative). I cant see the eagle footprint on the ssi site, your website and cant find it via google... hence my post.
socom93
Post by socom93 » Sat Sep 19, 2020 3:31 am
Interested by a kicad model if someone did it already ?
BugBrand
Knowledge of Bugs
Post by BugBrand » Sat Sep 19, 2020 3:35 am
Happy to see, if you do one.
Likewise, I ought to do one up.
(often find DImYself is anyways necessary for aesthetics in the schem)
Sure stocks will become available shortly - the IC has only just been generally released - only samples the last few months I think.
By the way, SSI are great to deal with - great setup!
& super wise/positive of them to get Neil Johnson on board.
forestcaver
Post by forestcaver » Sat Sep 19, 2020 3:42 am
Yeah - I agree on all those points - I’ve had some great interactions with ssi - they’re really good to deal with! I’ll aim to do one over the w/e.
Ps apple season! Cider! (Damn pandemic has meant we’ll miss the big group pressing and scratting this year! Also the Brizzle diy group has been on hold for ages!) I’ll send you a pm!
adam
Post by adam » Sat Sep 19, 2020 4:15 am
couriers bringing them by 5pm monday, all booked
forestcaver
Post by forestcaver » Sat Sep 19, 2020 4:28 am
<sigh> So you dont have stock - as I said... I still dont understand what you meant by “someone isn't looking very hard...”. Did you mean that some uk suppliers have stock or that there is an eagle part that I couldnt find? (It just seems an odd comment to make if you dont have stock and you dont know of an eagle part). I’ll wait until there is stock from where I plan to buy them.
