Steda Electronics SR-909 Drum Machine
SR-909 is exact replica of the 909 without compromises
Full Kit include:
Main board
Sequencer board
Output board
Midi/Sync board
Power supply board
DAC boards
Cherry switches
Cherry switches caps
Small Switches
Small Switches caps
7 Segments displays
All Potentiometers
All ICs
All Transistors
Power Transformer
All connectors
Steel Case (Powder coated and silkscreened)
All resistors
CPU
All Film Capacitors (Nichicon)
All Electrolityc Capacitors (Elna, Panasonic, Epcos)
We have 4 colors for Displays and LEDs.
RED, GREEN, YELLOW and BLUE.
https://www.stedaelectronics.com
https://www.instagram.com/stedaelectronics/
https://www.facebook.com/stedaelectronics/
Re: NEW DIY 909 DRUM MACHINE PROJECT
I just got proto board from factory.
I'll start build it tomorrow
- Attachments
- SR909_PCB.jpg (1.31 MiB) Viewed 7907 times
- mrand
I wonder if it would be possible or interesting to also have a standalone 909 sequencer box without any analog voicing. Just midi and trigger outputs.
Good luck with the project!
--ssdp--
sequencer board designed for ALPS and CHERRY switches and both fit perfect.
Soldering almost done. More pictures soon
- Attachments
- SWITCHES.jpg (717.15 KiB) Viewed 7744 times
- devinw1
Cool!
Do you intend to design an enclosure and bits to build up a whole unit? Or will this be aimed more for repair/restoration of existing units (which tend to sell for like $3000 or more
- dot matrix madness
- Veteran Wiggler
I second that emotion. A standalone sequencer box with just midi, trigger, and accent outputs would be ideal to work with arbitrary drum modules.
Licenced to solder since 1993
It's very cool.
I very much like this very much.
You know, that line that goes: "i want things that go Whooa and diuungg", like that nice man said to Bob Moog. That´s what I want too.
Soldering done. Time for testing
- Attachments
- DSC_0800.JPG (1.9 MiB) Viewed 7450 times
- Learning to Wiggle
Interested
Bought the Nava/Erica case but with the state of that project I know it’s not going to happen ...
I'd love to upgrade the power supply on my 909.
Im very interested in the notion of using the sequencer with the mb9090 clones. I have a working mb9090 that doesnt get enough use from lack of a sequencer
Im very interested to... im looking for a long time for a sequencer for my 9090(Trevor)
do you think it works on the Clone..
StormB
StormB
- realitycontrol
Amazing work so far.
I'm excited to see where this leads!
Installed seq board to original 909 case and it fit perfect)
- Attachments
- 909SQ_02.jpg (994.41 KiB) Viewed 7168 times
- 909SQ_01.jpg (1.26 MiB) Viewed 7168 times
- Altitude909
well shit, just when I thought I would never build another 9090. Put me down for one too. Shall I go fetch trevor and get him in on this?
- oozitron
- solder fume huffer
If you need a good "drum machine without sounds", build yourself a MIDIBox.
I put 4 MIDI outs on mine, plus 8 triggers (you can have up to 64), as well as 8 voices of CV/Gate.
You'll have yourself a fabulous drum programmer using just one of the 16 tracks. It's very much like the TR-606 programmer in that you can write/edit/save patterns while the thing runs. Up to 256 steps in a track. Loads of "shuffle" options, even custom shuffle templates.
Then you can program more drums, basses, 303s, chord stabs, etc on the other tracks :-)
Drew
Drew
Oh my...
I’m interested.
I’m interested.
Gum is fun, but not on a cat.
My minds an art gallery.
Interested
It works!
I'll post video to our instagram asap!
- Attachments
- seq01.jpg (295.35 KiB) Viewed 6968 times
