DIY MiniP7 Minipops7 clone *** Ext Trig and Audio Outs ***
Boogie
Post by Boogie » Fri Apr 06, 2018 8:33 am
2019-04-14 Audio Outs
2019-04-10 External Trigger Connections
2019-04-05 External triggering
some kits available
2018-08-02 Assembly Results
2018-07-20 Important Update
2018-07-20 Time to build
2018-07-16 Manual Updated
2018-07-12 First Results
2018-06-24 Now on Modular Grid
2018-06-22 Quick Reference Guide
2018-06-16 All packages shipped
2018-06-15 All packages ready, leave on Saturday
2018-06-15 Kits ready, waiting for boxes
2018-0604 Requests for Payment sent
2018-05-31 FrontPanels have arrived
2018-05-26 FrontPanels about to arrive
2018-05-19 2 units playing synchronous
2018-05-14 Pics and Audio Demo
2018-05-11 PCB assembled and running from first time
2018-05-11 PCBs received
2018-05-08 PCBs expected by cw20
2018-04-18 PCBs and Components ordered
Hello all,
I've split the DIY Minipops Clone thread into Minip7 and MP7.
One another to avoid missunderstandings.
This thread will hanlde MiniP7 which is the Clone of the origonal.
Rendered and Frontpanel that arrived today.
Image Image
All information of this project can be found at:
viewtopic.php?t=194996
Here you can find the whole development process, soundfiles, PCB renders etc.
In attachment to this post one can find the order form for the MiniP7.
OrderSheet_MiniP7_V3.pdf
(794.41 KiB) Downloaded 98 times
“Digital generated ‘analog’, is missing its analog soul and therefore isn’t analog any more.”
Jupiter 8 clone: https://www.muffwiggler.com/forum/viewt ... p?t=209322
Minipops 7 clone: https://www.muffwiggler.com/forum/viewt ... p?t=199360
ClapTrap clone: https://www.muffwiggler.com/forum/viewt ... p?t=202248
www.nabla-instruments.com
NANO-Jorge
Post by NANO-Jorge » Fri Apr 06, 2018 8:52 am
The panel looks nice!
Boogie
Post by Boogie » Sun Apr 08, 2018 10:25 am
Hello all,
Just to let you know,
The order opportunity for the MiniP7 ends today in week.
NANO-Jorge The panel looks nice!
thanks.
Boogie
Last day accepting orders
Post by Boogie » Sun Apr 15, 2018 6:06 am
Hello all,
today is the last day I will be accepting orders for the MiniP7.
(794.41 KiB) Downloaded 31 times
Boogie
Post by Boogie » Mon Apr 16, 2018 7:43 am
Hello all,
no more orders accepted for now.
B rgds,
Boogie.
Boogie
Post by Boogie » Wed Apr 18, 2018 3:33 am
Hello all,
PCBs and Components for the first production run are ordered.
To make sure everything fits with the mechanics,
I'll order the Fronpanels when the populated PCBs arrive.
Pls allow 5-6 weeks for the PCBs to arrive, according to the initial time frame below.
Planning outline.
Put prices online cw13 Done
Ordering till end cw15 Done
Order materials and populated PCBs end cw15 Done 3 days delay compared to initial planning.
SMD population (subcontractor needs about 5-6 weeks) cw21
Testing a couple boards cw21-22
Transporting the kits cw22-23
Fitchie
Post by Fitchie » Sun Apr 22, 2018 1:04 pm
Hi Boogie,
I was some time off, bit is it still possible to order the MiniP7 ?
It really would to be a fantastic add-on to my synth collection.
:yay:
And sorry for asking, but is there any chance to add a (3rd party) basic Midi-interface (as the Mini-implant) on your MiniP7?
Thanks.
Boogie
Post by Boogie » Wed Apr 25, 2018 2:48 pm
Fitchie
You're a bit late, but oh so lucky !! :bananaguitar:
I ordered 5 more (populated PCB's only, the rest you'll have to order yourself)
Of those 5, I have 3 left.
If you download and fill in the above OrderSheet_MiniP7_V3.pdf
I can tell you which serial nr you'll receive.
In case you insist on having midi,
I suggest to wait with your order till the completion and availability of the MP7
Pls visit the MP7 thread here: https//www.muffwiggler.com/forum/viewtopic.php?t=199361
Boogie
Components have arrived
Post by Boogie » Mon Apr 30, 2018 8:22 am
The TH components for the MiniP7 have arrived
Boogie
populated PCBs should arrive cw20
Post by Boogie » Tue May 08, 2018 10:26 am
Hello all,
I've just been informed that the production run of the PCBs wil probably happen this week which would mean that they arrive 1 week early. (cw20)
Planning outline.
SMD population (subcontractor needs about 5-6 weeks) cw21 probably cw 20
ST.P
Post by ST.P » Tue May 08, 2018 3:25 pm
Thanks for the update :tu:
makhho
Re: populated PCBs should arrive cw20
Post by makhho » Tue May 08, 2018 5:32 pm
Boogie
Post by Boogie » Tue May 08, 2018 11:34 pm
makhho
where can this information be found?
Original thread before splitting into MiniP7 and MP7
3th post on this page:
viewtopic.php?t=194996&postdays=0&posto ... &start=250
if you still want to order, pls use the latest format published in this thread in the first or third post.
TH components can not be ordered, from me, anymore as the kits have been made.
A couple SMD populated PCBs are still available,
As I will only order the FPs after a first mechnical fit on the final boards, I can still expand my order of frontpanels.
So SMD populated PCB and FP can still be ordered.
Boogie
SMD populated PCBs have arrived
Post by Boogie » Fri May 11, 2018 3:55 am
I will further update about debugging and assembly over the next couple weeks .
As soon as the first one fits my FP mechanically, I'll order the rest of FPs.
planning wise
SMD population (subcontractor needs about 5-6 weeks) cw21 Done 1.5 weeks faster then expected compared to initial planning.
Boogie
Running as from first time
Post by Boogie » Fri May 11, 2018 10:05 am
Running from the first time ! :bananaguitar:
I assembled one PCB this afternoon and powered it up.
After programming the processor, it ran from the first time.
I have to check on a couple values of resistors as the volume balancing might need some small updates (change the value of a resistor)
Apart from that, it's all looking very good.
Mechanics fit perfect.
Some pictures below.
At this tempo, debug should not take a couple weeks. :hyper:
Dr Gris
Post by Dr Gris » Fri May 11, 2018 1:24 pm
Great news!!! :love:
I guess it's time for me to start thinking about enclosure and power options.
I'll be bringing it with me to live gigs as a standalone unit :party:
//M
Fitchie
Post by Fitchie » Fri May 11, 2018 1:57 pm
Impressive !!!
Boogie
Post by Boogie » Mon May 14, 2018 1:25 pm
Since the V2.01 has quite an updated schematic compared to the V1.01,
I had to redimension a couple values.
No trace cuts or additional wires.
Audio demo already recorded but still to be put in video format.
That's for later tonight or tomorrow.
NANO-Jorge
Post by NANO-Jorge » Mon May 14, 2018 3:33 pm
It looks superb! What microcontroller IC are you using? Just being curious :mrgreen:
Boogie
Post by Boogie » Mon May 14, 2018 4:00 pm
NANO-Jorge
It's a dsPic33FJ256GP710a, way too big for the application, but the standard I use for most of my projects.
Boogie
Post by Boogie » Mon May 14, 2018 4:02 pm
And here's a first audio demo of the first MiniP7_V2.01.
You may find some slight overdrive from 30 to about 40 sec.
Boogie
Synchronising two MiniP7 drumcomputers by external clock
Post by Boogie » Sat May 19, 2018 9:40 am
Below a movie in which two MiniP7 are synchronised by means of a synchro signal and external clock.
All remarks/questions welcome.
makhho
Post by makhho » Sat May 19, 2018 5:22 pm
Boogie
Post by Boogie » Sat May 26, 2018 3:35 am
FrontPanels are about to arrive.
Planning outline.
Testing a couple boards cw21-22 Done cw 21
Boogie
Post by Boogie » Thu May 31, 2018 2:55 pm
Hello all,
Front panels have arrived,
and...
they fit :banana:
I will complete the kits and send out the requests for payment during the coming days.
