Animal Factory Amplification
Soma - LYRA-8 DIY Kit
Just wondered if any of you Synth DIY gods are making one of these?
I think it is the most interesting sounding synth I have heard for quite a while and the price seems good..
Just PCBS and a few rare IC's in kit.
A big thread in General section on the prebuilt version but I haven't seen anything here.
I just bought a kit so am pretty excited - hope I don't fuck it up. Need to find a decent enclosure for it.
This is info:
For all willing to assemble their own LYRA, we have made 50 DIY kits for LYRA-8 and 25 kits for LYRA-4.
Price:
LYRA-8 - 100$ (92 euros)
LYRA-4 - 80$ (74 euros)
Plus delivery 26-33 euros and 3 - 11 euros of money transfer commissions (depending on the selected money transfer system).
The kits available without a queue.
To get a DIY KIT send your request to omhohom@gmail.com
Please write in the title “LYRA-8 DIY” or “LYRA-4 DIY” depending on which kit you want to buy. Also, please mention in the letter the country where you want the kit to be delivered.
DIY kits are aimed at experienced radio enthusiasts and require making the body and front panel of the synthesizer according to your abilities and taste.
This is info:
Price:
Yep, no synth god, but I was on waitlist, have ordered and am currently following the tracking
Think there is one of the bigger common pedal type boxes that will fit, Ill post here when Ive done the measurements etc.
The Retail for built ones are more than fair as well, but theres quite a long waiting list already I think.
That would be great if you had info on a decent case.
I like the big sloped Hammond cases that are beige with blue sides but it is a powder coat finish and when I made a pedal using one I couldn't get waterslide decals to work at all..
That might be a tough point for me getting any graphics looking OK - quite a lot of knobs to not have any labels!
- mangros
If you use a product like 'Micro Sol' or 'Micro Set' then you can get waterslide decals to soften up and hug the surface texture a lot better.I like the big sloped Hammond cases that are beige with blue sides but it is a powder coat finish and when I made a pedal using one I couldn't get waterslide decals to work at all..
The softer the decal goes, the more likely it is to warp on the surface, but it does work. Here's a Hammond case I did (after few coats of Plastikote clear)
Futuristic fonts: http://disasterfonts.co.uk
So 12x12 for the inching ones should work fine, and so will this:
http://no.mouser.com/ProductDetail/Hamm ... y55g%3D%3D
- lasesentaysiete
I ended up splitting my order between a few different suppliers: Mostly Tayda, some Mouser, some R-S, some local. Total cost without case is ~100€
For the enclosure, I will most likely go with Bud Industries AC-1424. 12"x12"x3".
The thumb screws: http://www.automotioncomponents.co.uk/e ... l/p0405.zp
Well goddamn... I was just telling myself not to commit to any more projects bigger than a 4hp passive attenuator so... I ordered the Lyra-4. Anyone else here building a 4? If I should butt out and start a new thread do let me know.
I took a glance at the BOM and it seems fairly straightforward but there are couple things I was scratching my head a little on.. if anyone does end up posting a mouser cart or similar (even partial, for the Lyra-8), that'd be great. Even for instance... anyone have recommendations on a stable 12V power supply for US plug?
lasesentaysiete
Those Bud boxes look nice, good call.
Any brave individuals thinking of adding additional CV ins or even switches to vary between "tweakable" caps for the distortion and delay LPFs (possibly not worth it)?
lasesentaysiete
- Learning to Wiggle
So, I got my boards and I have a few questions.
1, Are we going to post our building questions on this forum or are people contacting Vlad directly? (would be better to post theme here and have Vlad answer them so that everyone can see the answers).
2. Is there a drill template? I've seen the design for the front panel but can that be scaled correctly for a drill template?
3. Is the PCB with the pots/switches meant to be mounted directly against (in contact with) the aluminum enclosure? The pictures certainly look like that is the way its constructed. I noticed that the side of the PCB that mounts against the enclosure has bare pads (which would make contact with the enclosure) which would mean it would need to be isolated somehow.
4. There is a resistor listed as "3 mom", I'm assuming this means "3 Megohm"?
Thanks,
David
Thanks,
David
I asked Vlad about the thumb screws and the part we'll need to source is DIN653, but other kinds of screws will also workJcsveth wrote:If anyone finds a US supplier for those knurled thumb-screws please post. I do not think I'll end up with them but want to build it to 'stock' and then play around when casing it.
I just took a look at the build doc for the L4 and it's gotta be 3 Meg. That one appears at the top and values descend from there. The resistors that have no K or M multiplier designation at the bottom are also listed as "300 om" for example.Oscilloclast wrote: One thing I was confused about was the "3 mom" resistor, which I'm assuming means "3 Megohm"? Is that what you think?
I'm curious to see if anyone has any creative solutions for that cabling. Maybe molex connectors?
- lasesentaysiete
does anyone else find the control board design an odd choice? I mean that instead of having the pcb-mountable components mount to the pcb via regular footprints, we get this sort of smd type style with THT components. Anyone know why this is?
I actually don't mind it, btw. But it seems an unnecessary amount of work.
