DIY builders for hire
chachi
Re: DIY builders for hire
Post by chachi » Wed Jan 15, 2020 2:07 pm
is this the right thread for repair people? i’m in portland, or. and i have a kurzweil K2000 that lost its will to live and a CS-60 that needs adjustment. i have used Tim in the past and want someone else. thanks!
AC-130U
Post by AC-130U » Wed Jan 15, 2020 2:13 pm
Hey, I'll build for people in SMT and through hole, 5U or 3U format, doesn't matter.
I will also be willing to make cases within the near future - acquiring woodworking tools at this time.
I'm in the Provo UT area.
AC-130U
ancientbones
Post by ancientbones » Sun Jan 26, 2020 6:04 pm
Anyone in the US build full custom synths? I’m interested in commissioning something like a stripped down, durable Roland sh-1000. All I’m looking for is 2 vco’s, a filter, a simple envelope generator (attack & decay), and two LFO’s and a small keybed. 37 keys would be fine.
I have experience soldering, but I’m not a woodworker so I’m not sure how I’d pull off building a case and wiring a keyboard.
djs
Post by djs » Tue Jan 28, 2020 10:29 am
More complex than what you're looking for, but have you seen this?
https://synthcube.com/cart/diy-kits/no- ... er-deposit
pfzzz
Re:
Post by pfzzz » Thu Feb 13, 2020 9:35 am
alexam wrote:
Fri Nov 08, 2019 9:17 am
Hello there,
so because i got a lot of fun at building up my little modular, i would like to offer you building up modules for you.
I build several Mutable Instruments Modules (also the Ambika and some Shruthis), some MFOS stuff, worked a while at a music store where i repaired digital pianos on component basis and did some modifications to a lot of stuff which i am using to make some kind of music.
so basically, i got a nice hot air station and a nice soldering iron and all the equipment, that is needed for tasks like this and i know how to handle them. So if someone is interessted just write me a message.
- I am located in germany and could ship within europe
best greetings!
I cannot send messages for some reason, please send an email to pfzzz.pfzzz[at]gmail, need to build some modules
Building the future at the Bookla Foundation! ⨇⋀ᴧ
welhamc
Post by welhamc » Mon Feb 17, 2020 7:12 pm
I'm located in Bristol, UK. I am happy to offer a range of DIY services including module building (5U/MOTM/Eurorack/4u), power supply building and some repair services. If you have anything to ask please PM me!
theianscott
Post by theianscott » Mon Mar 23, 2020 7:37 am
Hi All,
I am just getting into EuroRack and I have a Pittsburgh Modular MIDI3 - bought it second hand, it is my first extender module for a DFAM and M32 combo. Using it with a RowPower 30. It wasnt working when it arrived, I think I tried to power into the wrong connector (the extender connector?) located the right one, and still no luck to power it up.
In desperation I flipped the power cable and got the grey smoke of death. Contacted Pitsburgh Mod who said they could sort it, but I am near Manchester in the UK so it isn’t practical to send it off. Whilst I could probably have a pop at it myself… think I have done enough damage as it is!
Is there a decent EuroRack medic I could post it to? Possibly the RowPower too so I can get a full bill of health before I get it back? I am thinking there must be some self isolating engineers in here now! :)
Thanks in advance.
Staticcharge
Post by Staticcharge » Tue Mar 24, 2020 4:24 am
Hi All,
Thanks in advance.
I've sent you a PM. I've built through hole and smd, early days: turing machines and FC monoblock modules etc. Recently: Plaits, SMR, Performer sequencers and Stages, rings, Elements and so on.
I'm based in Kent but I've finished/repaired modules built by a guy not far from you, Ben Parsons in Prestwich, you may not of heard of him but it's a small world.
Boneoh
Post by Boneoh » Sun Apr 05, 2020 8:58 am
PM sent.
EATyourGUITAR
has no life
Post by EATyourGUITAR » Thu May 21, 2020 11:19 am
only pittsburgh has the software needed to finish the repair. I don't think they will distribute that around the internet. you may be wasting more money sending it to people who definitely don't have what it takes or at least not without the help of pittsburgh.
elmegil
Post by elmegil » Thu May 21, 2020 12:04 pm
I have arranged repairs of Doepfer MIDI where the controller chips was bad by getting the programmed chip from a Doepfer representative in the US. Something similar may be possible with the Pittsburgh, without getting into proprietary IP.
Radtron
1-Post Wiggler
Post by Radtron » Tue Jun 30, 2020 9:28 pm
I bought an ornaments and crime module from someone in Puerto Rico. Not to long after I bought it the module only outputs the same voltage from all CV out jacks. I noticed when I push the pot it creates some noise. I inspected the solder and didn't note any bridges or bad solder jobs. I suspect a bad pot. Is there anyone willing to look at it? Thank you for your time.
KitKatAndy
Post by KitKatAndy » Sun Jul 26, 2020 3:41 am
I`m offering DIY builds - through-hole and smd.
I`m located in germany.
Quality: I do all my stuff with very high patience, rechecking everything three times and do rework where necessary til it fits my personal aspiration. I build all the stuff like I would do it for myself not for money.
Here are some pics of my latest works:
laplace13
Post by laplace13 » Sat Sep 19, 2020 7:34 am
Hello, I'm an experienced builder with EE degree based in NYC and VT. I've just finished a run of 4 TTSH 2600's with all the standard mods, as well as 3 NAVA 909's. Photos or videos of either can be sent by request. I also do general synth repair, with lots of experience with Yamaha CS-5 & 10, Roland Juno 6/60/106, Roland RS-101/09, Sequential Prophet 600, Simmons SDSV, Tama Techstar, Moog Prodigy and battery on Korg Poly Six/61's (especially battery acid PCB repair). Experienced with KIWI Mod installations as well as Poly Sex mod on Poly Six Synths.
ancientbones
Post by ancientbones » Fri Sep 25, 2020 1:32 pm
Anyone in the US doing Behringer TD-3 mods?
I’d love to get mine modded out with the following. I’m based in Detroit so if you’re in Michigan let me know!
Mods I’m looking for:
Rubber mod
Sub-osc
FM
VCA crunch mod
Accent decay
VCA decay
Manual accent trigger
3vcos
Must have slack/modules
Post by 3vcos » Sat Sep 26, 2020 8:44 pm
I'm looking for someone to finish a couple modules in Wiard 300 format. I just don't have time for this these days.
Quad 281 module. I have the front panel and pcbs.
Dual Fonitronik attenuverting mixer. I have the panel and stuffed pcbs.
Lots of work here including how to tastefully mount the pcbs off the panel. Looking for an experienced builder.
snowtires
Post by snowtires » Mon Sep 28, 2020 12:12 am
What's up, if anyone in Eastern PA (or anyone willing to ship) is looking for DIY Eurorack modules or synth builds, drop me a line. I've built about 30 different modules and numerous different synth boxes, just let me know what you're interested in!
Zegobs
Post by Zegobs » Thu Oct 08, 2020 1:30 am
Hi all,I love this community!
I am looking for someone in Europe or even France to build and calibrate a µO&C for me. plz PM me
Nick Thorburn
1-Post Wiggler
Post by Nick Thorburn » Sat Oct 17, 2020 3:43 pm
Hello,
I am a builder for hire from Niagara Falls, Ontario, Canada. Please message me if you need kits or cases built/repairs! I can do SMD, and flash IC's. Price is pay what you want, all I ask is that you pay for shipping and raw components.
- Nick
exper
Post by exper » Sun Nov 08, 2020 3:32 pm
Looking for someone who is willing to do some simple work (POTI repair, some passive switches, etc.) Probably best if based in the US.
PM me if anyone is interested and I give give more details. I'll update post if I find someone.
Thank!
_____________________________________________________________________________________________
Synthacon
Post by Synthacon » Fri Nov 13, 2020 7:57 am
Looking for someone to build some Oakley Euro modules in the UK.
You always want just one more synth
oppositaer
Post by oppositaer » Sun Nov 22, 2020 5:29 am
Hello there, I am always available for assembling DIY kits, also non Eurorack. I am in Italy but can ship worldwide. Actually I have assembled some kits from Befaco and AI Synthesis ready to ship. PM me for detailed infos.
PS. due to lack of time I am not available for designing projects or something similar.
I build DIY kits and projects in South Europe.. PM me if you need help!
Some sounds:
https://www.mixcloud.com/oppositaer/
https://soundcloud.com/arinev
pettycash
Post by pettycash » Thu Nov 26, 2020 5:56 am
If anyone needs synth repair/service in London.
Please get in touch, I have the relevant training in electronic fault finding and would be happy to help :tu:
Super Hydro
Post by Super Hydro » Wed Dec 09, 2020 3:32 pm
I had Chris work on a module starting in September. In October he sent me a message that me is almost done but that he had some issues, but that it would be done the next week. I then emailed him in early November and never received a response. Then emailed again last week, no response again. Does anyone know him personally? Firstly, I hope he is ok. He has received some good reviews on here so I don't suspect anything foolish.
thanks
hustlerwhite69
Post by hustlerwhite69 » Thu Dec 10, 2020 4:39 pm
Hello!
I'm lookin for someone to troubleshoot and finish a Psycox Syncussion SY 1M kit that I almost finished building earlier this year. I'm fairly confident that I soldered everything in the right place, and the thing powers on and makes sounds, but not the sounds it's supposed to. I contacted Simon who makes the kits who suggested that it's likely an issue with the SMD transistors. Here are videos of the weird sounds that it makes: and I live in LA county so it would be ideal to find someone nearby but open to shipping the kit too. Send a PM, thank you!
