Behringer 2600-VCO Eurorack Module
SkyWriter
Post by SkyWriter »
One coming to me next week from sweetwater. Whee!
give a hoot, don't fucking pollute.
brandonlogic
Re: Behringer 2600-VCO Eurorack Module
Post by brandonlogic »
No experience with the 2600 single vco module but I have a full behringer 2600 synth and it’s amazing.
SkyWriter
Post by SkyWriter »
brandonlogic wrote: Fri Jan 07, 2022 5:39 pm No experience with the 2600 single vco module but I have a full behringer 2600 synth and it’s amazing.
Same here!
I'm hoping it's as stable and well behaved as the B2600's VCO's are.
brandonlogic
SkyWriter wrote: Fri Jan 07, 2022 6:00 pm
Same here!
Yeah I was surprised when I turned on the 2600 to work on a patch I working on 3 days later and all 3 oscillator where still perfectly in tune! That never happens in my eurorack.
SkyWriter
Post by SkyWriter »
brandonlogic wrote: Fri Jan 07, 2022 7:31 pm
Same here!
I tuned my Behringer analogs once they're all warmed up. I haven't had to retune them in weeks unless one of the ferrets scrambles around the tuning pegs/knobs. The part I appreciate about their synths - like B2600 - is the tracking is accurate from the factory. The eurorack VCO's... eh, not so much.
Since it was a single item, it's taking the USPS slow route.
SkyWriter
Post by SkyWriter »
boop!
LED's TOO BRIGHT. another of the new potentiometer packaging. these kind of suck. theres no visible value printed on them. I have to pull one to see if it's stamped on the bottom - or just a place I haven't seen; printing on the bottom is too stupid for words - but I can see the same brand stamped on the side, so we're dealing with new parts inventory.
I'll take it apart tomorrow when there's better light to see.
SkyWriter wrote: Wed Jan 12, 2022 6:39 pm I'll take it apart tomorrow when there's better light to see.
Looking forward to it. ;)
SkyWriter
Post by SkyWriter »
hmm, so yeah, there is no way to check the value of this potentiometer without removing it. wow.
the hard one to read is a 5173.
ugh, the sliders are also unmarked. wtf is this...
SkyWriter
Post by SkyWriter »
four more in stock at sweetwater!
all gone.. and I was going for another. :0)
SkyWriter
Post by SkyWriter »
I like the separate waveform outputs of this VCO better than the B1004 toggle select as an LFO.
I put it through some casual paces, and it sounds as good as the B2600 VCO's. the OOTB sine symmetry needs some tweaking.
but, it sounds good! not sure how you can make one make a four-waveform VCO sound bad... tracking is good.
once I trace the brightness LED's I can leave it on without acid-burnout-eyeballs.
Thanks for the pics Skywriter! :tu:
The thing that stands out for me most -in a good way- is the slide switch. Note the extended legs. instead of simply extending the plastic of the actuator as so many switch mfrs prefer. Much better mechanics and likely a fractopenny more than the more common longer actuator method.
This to me shows that at least 'someone' at Behringer is looking at more than cost.
Edit: Or that they're playing to people like me and have taken out far more fractopennies somewhere else! ;)
SkyWriter
Post by SkyWriter »
I'm interested in seeing what's coming out of the pipeline with audio taper pots. All the new build stuff has linear parts - or they were in the originals.
Tomorrow the B1027 comes and I can button up the bottom part of the BARP rig's packaging.
SynthBaron
Post by SynthBaron »
I wonder how much are emergency part substitutions due to shortages.
Kind of odd there's not even a simple jumper to kill the power to the LED's, never mind a different resistor value option, considering the complaints on their full 2600 clone brigthness/colors.
jac.k
Post by jac.k »
never buy a jptrfx pedl if the 2600 vcoled is too bright - i burned my eyes out with the jive haha
i think this osc module very good too, great sound
