Clock Divider and reset
evs
Post by evs » Mon Feb 15, 2021 5:41 pm
i have two clock dividers that are considered doing musical and not mathematical divisions.
That is the G8 and the Time Wizard.
But there's something i don't understand in their behavior.
I reset both on start. But they divide mathematical...
meaning if they divide by 2, than 2 and 4 is high. NOT 1 and 3...
(as i understand 1 and 3 would be considered musical..)
my set up here: a machinedrum gives out midi clock to a doepfer a-190-8.
There i patch a clock out to one of my clock divider and i patch the start to the reset in...
all the outputs go high on the second clock... and not on the first one...
what am i missing?
Edit: changed the title as it is misleading..
mosorensen
Re: Reseting a Musical Clock Divider
Post by mosorensen » Mon Feb 15, 2021 5:54 pm
Does this discussion help:
viewtopic.php?f=16&t=232678
evs
Post by evs » Mon Feb 15, 2021 6:05 pm
not really, they just say what a musical and what a mathematical divider is.. i saw it earlier and he is just saying what i´am saying. at least i believe so.
but question is, why do my musical dividers behave mathematical?
mosorensen
Post by mosorensen » Mon Feb 15, 2021 6:17 pm
Maybe they really are mathematical, not musical?
evs
Post by evs » Tue Feb 16, 2021 1:44 am
No, the mistake mist be somewhere else..
evs
Post by evs » Tue Feb 16, 2021 2:16 am
It seems that they divide musical, but that the first trigger in does not count..
For instance if I divide by four, they all go up on the beginning at the Second Input.. neither a mathematical or a musical divider would do this.
So it seems that they ignore the first clock coming in.
Both the time wizard and the g8 are doing it.
So I guess there Must be something with the a-190-8...
tokidoki
Post by tokidoki » Tue Feb 16, 2021 2:33 am
Could this help ?
" I just got a G8. The different modes are great - the first mode is the same as the A-160, but "musical". Not remembering the last mode used is a PITA, just like the uscale. As I have 2 uscales and a G8, switching on the modular is a bit like booting up a computer - I have to set up 3 modules before it sounds right. Hopefully a new version of both modules will remember the last mode (one day!). "
viewtopic.php?p=1307182
And did you check the "Wait control input" in the Doepfer module ?
http://www.doepfer.de/a1908.htm
andybizarre
Post by andybizarre » Tue Feb 16, 2021 2:38 am
Perhaps your modules` reset inputs react to the falling edge of the reset gate. That could explain the "missing first clock". Un-check jumper JP9B and see if it helps.
I have an A-160-2 and had to do a bit jumper setting myself until it behaved the way I needed it to be.
tokidoki
Post by tokidoki » Tue Feb 16, 2021 2:44 am
Perhaps your modules` reset input react to the falling edge of the reset gate. That could explain the "missing first clock". Un-check jumper JP9B and see if it helps.
We had to use this module to fix a similar problem with our clock system :
http://www.doepfer.de/a165.htm
Perhaps it could be possible to find one on the used modules market.
evs
Post by evs » Tue Feb 16, 2021 6:02 am
I‘ve tried that, the g8 and the Time wizard seem to react on the rising edge..
I have set the start to trigger and not to gate on the Doepfer.
I tried a bit further and used a maths and a brain+pp as The clock and reset givers. Same thing there. A bit weirder even. I made a video to show this.. I will try to link it in a minute..
Please pay attention how the g8 reacts differently each time..
Explanation: maths into clock divider. Also into brains to clock it. Gate out of step 1 of pp into reset of dividers.
evs
Post by evs » Tue Feb 16, 2021 11:39 am
oh, and about the videos, have a look when the sequencer is on the one, and when there is a reset happening at the divider on the left..
helix
Re: Clock Divider and reset
Post by helix » Tue Feb 16, 2021 1:52 pm
http://ladik.ladik.eu/?page_id=2857
Is this maybe what you need?
evs
Post by evs » Tue Feb 16, 2021 3:42 pm
Ah, maybe! Guess I will try first patching something like that with maths (should be possible, or?) and if it works I’l buy that..!
andybizarre
Post by andybizarre » Wed Feb 17, 2021 7:41 am
The issues which are (hopefully) solved by the Ladik U-090 are discussed in depth in this thread: viewtopic.php?f=16&t=166898&hilit=du+seq&start=150
You might find some similarities to your problem there.
evs
Post by evs » Wed Feb 17, 2021 4:19 pm
Thanks for the link!
evs
Post by evs » Wed Feb 17, 2021 4:21 pm
I tested a bit, and the Interesting thing is that when I delay the reset trigger nothing changes, but when I delay the main clock a bit (with a maths) than everything runs as expected!
andybizarre
Post by andybizarre » Thu Feb 18, 2021 2:52 am
Glad this worked out. I have to find a solution for this myself, as my DuSeq behaves exact the same way. Luckily I`m clocking and resetting my whole modular with Expert Sleepers and Reaktor, so I can to patch this up ITB. No need to buy more modules, hehe.
dubonaire
Post by dubonaire » Thu Feb 18, 2021 7:26 am
That makes complete sense. The reset has to occur before the clock advance.
continuum
Post by continuum » Thu Feb 18, 2021 8:10 am
It has to be synced with the clock pulse. That is the only way to get reliable resets.
Tiptop Audio R&D
www.tiptopaudio.com/
evs
Post by evs » Thu Feb 18, 2021 4:12 pm
Strange that it’s not at the same time from the Start..
Do you think it’s a Problem from the doepfer module or from the machinedrum?
