Gate delay devices - why so few and unavailable?
- galanter2
Perhaps I'm missing something here.
There are any number of modules for managing gates and triggers. We have dividers, boolean operators, clocks that lock, electronic switches, etc etc.
So why are there so few modules for simply delaying a gate? What do people do when they want an evolving sound, and some aspects don't become active until well after the attack?
The only one I can find available is the Doepfer A-162 Dual Trigger Delay. That one is (IMHO) wider than need be, and it only has one gate-off mode. (One would like a choice…end the delayed gate when the input gate ends, end the delayed gate after a fixed interval, end the delayed gate in the same amount of time as the input gate. Also I want long delay times…10 seconds or more.)
http://www.doepfer.de/a162.htm
Something closer is the Ladik S-186. Except it's out of stock everywhere as best as I can tell.
http://ladik.ladik.eu/?page_id=1717
It's tempting to just build my own. I could probably whip up a quad delay by using an Arduino and level-matching buffers. But I'd rather just pay someone to do it and spend my time recording.
Thoughts?
Thoughts?
Re: Gate delay devices - why so few and unavailable?
2hp Brst andMalekko Quad Gate Delay might be good options.
New track! Our first release in a year and a half. Mostly based on the TINRS Fenix IV.
- galanter2
(I have a couple Expert Sleepers Disting V4's which offer mode H-6 Dual Delayed Pulse Generator. But this doesn't pay attention to the duration of the input, just its starting point. IE it's for triggers more than gates.)
mutable instruments stages?
sound sources < sound modifiers < modulation sources < utilities
- galanter2
Thanks! What misses the mark for me is that the module doesn't pay any attention to the duration of the input gate. It outputs a gate with an independent duration. (It is voltage controlled, so perhaps there is a way to turn the duration of the input gate into a voltage via integration or the like. But that's a long way around. I suppose I could use an AND gate to cut off the delayed gate when the input gate ends for that mode. Still a 3 way selector and internal circuitry for the 3 gate-end modes would be much easier to use.)
Ladik S-186/S-189?
I never used them but they look fine and are cheap.
I use the Klavis Logica XT for gate delays. It also does a million other things.
- mdoudoroff
The Malekko Quad is pretty neato.
- galanter2
But the 2hp Brst sends out triggers not a delayed gate. The Malekko unit only delays up to 1 second (although perhaps this can be finessed by faking an input clock for its sync mode) and doesn't pay attention to the duration of the input gate.
That DIY idea is starting to look better...
- GuyaGuy
Some envelopes already have a delay stage. But it looks like there are about 20 options:
https://www.modulargrid.net/e/modules/b ... ection=asc
- Veteran Wiggler
Malekko unit absolutely does preserve gate duration. It's a great unit, just wish it had a gate-to-trigger mode.galanter2 wrote: ↑Sun Jan 26, 2020 4:56 pmThanks!
- galanter2
Thanks! But that's more of an envelope generator, and it's wider than a simple gate delay needs to be. It's also about 4X the price of what I need should cost.
It could be coerced into being a gate delay (make envelopes that look like gates), but that seems like a long way around for simple gate delaying.
- galanter2
Thanks! I mentioned the S-186 as being out of stock everywhere (?), but the S-189 seems to be available. I'd rather the two channels of delay have independent inputs (like the S-186) rather than a common input (like the S-189) but that's not a deal killer. To end the output gate when the input gate ends I'd have to use an AND gate. I'd be able to set the duration, but what I wouldn't be able to do is delay the gate and then hold it for as long as the input gate was held.
I'm going to reconsider the S-189 + AND gates though. So thanks again.
- galanter2
Hey thanks! Interesting module. However, I can't see how it is used as a simple gate delay, and how all 3 end modes can be supported (off when input off, off after a set duration, off after the same duration as input).
- starthief
When I feel like I need a gate delay, I use:
- Stages does it easily, when I remember
- Maths, rise time = delay amount, EOR = the delayed gate. Set fall time equal to rise time if the gate length has to match the input.
- Teletype, but that's much easier to use for trigger delays than gate delays.
- abelovesfun
This can also be done easily with vanilla modules that you may already own - just think like a modular.
All you need is your gate to be multed in order to trigger a separate ADSR ("DELAY ADSR") in between the gate and what you want to trigger, like another ADSR ("MODULATION ADSR").
By adjusting attack on the DELAY ADSR, you will delay the rate at which voltage climbs going to the gate input of the MODULATION ADSR.
This depends of course on the gate threshold of the MODULATION ADSR, but is pretty simple.
Let me know if you have any questions.
Super Easy, Awesome DIY kits @ http://www.aisynthesis.com
modular ambient and composery music @ http://www.forcedamage.com/
https://www.facebook.com/forcedamagemusic
- GuyaGuy
^Yep came back to say this but abelovesfun already did!abelovesfun wrote: ↑Sun Jan 26, 2020 5:52 pm This can also be done easily with vanilla modules that you may already own - just think like a modular.
Yeah, it's not super clear how it works right away. It's basically a gate S&H with delay. It needs a clock in and will delay a gate signal (or pattern) by the amount of clock steps. You use a dial to adjust from 1 -128 steps. So not really a "simple gate delay." I would think you could get your desired end modes by stopping the clock input signal at the appropriate interval.Hey thanks! Interesting module. However, I can't see how it is used as a simple gate delay, and how all 3 end modes can be supported (off when input off, off after a set duration, off after the same duration as input).
The second mode works the same way but you don't necessarily need a clock input. And without the input you wouldn't really get anything like the end modes you're looking for.
From the manual:
1. Pattern delay
This is useful to create delayed rhythmic patterns.
A regular trigger/gate at typical pattern rate is brought to the clock input.
A gate pattern is brought to the data input
The output will provide a delayed copy of the pattern but shaped with the phase and duration of the trigger/gate signal.
2. Digital delay line
This is used to arbitrarily delay a digital signal for up 5000 steps with a clock of any rate. Contrarily to the previous mode, the output signal is not reshaped according to the clock shape.
When no jack is present at the clock input, the module generates its own 1 KHz clock internally. This gives you a delay adjustable up to 5 seconds with a 1ms precision.
By maintaining the Xtra button pressed, the right half of the pot allows adjusting the delay from 1ms to beyond 5000ms. The LEDs are lit in bargraph way.
- galanter2
Yes, many of these are something different, or more, than just gate delays. Once you start using envelope generators with delays to create a gate delay…which is intended to make some other envelope delay…it seems a bit strained relative to a (hypothetically proper) gate delay.GuyaGuy wrote: ↑Sun Jan 26, 2020 4:57 pm Some envelopes already have a delay stage. But it looks like there are about 20 options:
I suppose a gate delay could be made like this:
V+ below AR out ——-->
gate -> AR envelope -> comparator -> delayed gate out
A then adjusts the delay time. R=0 makes the output cutoff when the input does, other R's increase output gate length. But still missing is making the output gate time the same as the input gate time.
(EDIT - R can be adjusted so the delayed duration matches. What this can't do, however, is allow the output gate to end *before* the input gate.)
I realize I'm being pretty fussy here. But I'm coming to the conclusion that no device matches my needs.
* Long delays (10+ seconds)
* mode 1 - gate out ends when gate in ends
* mode 2 - gate out ends some (knob) duration after gate out starts
* mode 3 - gate out ends to achieve the same gate duration as gate in
For each channel of delay this would require 2 jacks (in/out), a knob, and a 3-way switch.
(thinking out loud about a DIY)
- galanter2
Thanks, but this converts triggers to gates. It can't respond to the duration of the input.
- galanter2
Maths could probably do it. But it's big (a 4 HP panel should be all a gate delay needs), plus this trivial concern…I hate the Make Noise aesthetic! Maybe if I got an alternative front panel somewhere.starthief wrote: ↑Sun Jan 26, 2020 5:51 pm When I feel like I need a gate delay, I use:
Good suggestion though.
- galanter2
Sorry…I more or less reiterated this in my post out of sync.abelovesfun wrote: ↑Sun Jan 26, 2020 5:52 pm This can also be done easily with vanilla modules that you may already own - just think like a modular.
