Braids Renaissance (robot speech, 10 new chord modes)
xcc
Re: Braids Renaissance (robot speech, 10 new chord modes)
Post by xcc » Fri Dec 25, 2020 5:52 pm
th0mas wrote:
Fri Dec 25, 2020 5:25 pm
Find "wave" in the global list and press the encoder
That should do it. The Braids interface is deceptively simple.
dooj88
Post by dooj88 » Fri Feb 19, 2021 9:26 am
i have to say i've been using this since you announced it, and absolutely love it. the SAM models make some really interestingly glitchy sounds.
and while i'm here, since you're knowledgeable with firmware modification, wondering if bytebeat alogs would be possible to use on braids. might be worth it for me to finally crack into the code to mess around with if you think it's not impossible.
ArchieFunker
Re:
Post by ArchieFunker » Fri Feb 19, 2021 1:44 pm
pisrecords wrote:
Wed Mar 27, 2019 8:56 pm
:sb: thanks for this firmware !!!
i love a lot the chord modes. very helpful for my live performance !
i am using braids renassance 0.4 with Winter Modular Eloquenser . i use 1 sequencer cv out for control oscillators modes in META . the sequenser only have quantized output . i use it in SEMITONES , but i have a little problem :
some Braids OSC modes not change well . these are varying between 2, generating noise. as when a quantizer can not define correctly between 2 notes. This, if I remember correctly, did not happen to me with other firmwares.
I'm a full on noob when it comes to this stuff, but what I have done to dial in and switch through waves using META, is use the SEQ "module" on my Pico System 3. The unquantized steps allow me to dial in 4 different waveforms, then sequence trough them using a random pulse, or trigger from a different sequencer. Using the little step switch to select 2, 3, or 4 steps in the SEQ makes it interesting. I can't remember if I was able to get the full range of waveforms though, either way it was a fairly broad range.
PS. Thank you for all the hard work on this firmware Th0mas, I absolutely love it!
th0mas
Post by th0mas » Sat Feb 20, 2021 1:26 pm
On Braids, yes, it would work. I believe Bees in the Trees might have bytebeat algos.
You will likely have issue fitting more algos into Braids Renaissance. I think I was like 60 bytes away from filling the stack? Something like that. You will probably have to remove something in order to add anything new.
If you try this feel free to start a new thread about modifying Braids firmware and ping me on it, I'd be happy to help when I have time
Tboy
Post by Tboy » Sat Mar 13, 2021 2:02 pm
I was wondering, is there a cheat sheet out there with all the different synthesis models that come with Renaissance?
th0mas
Post by th0mas » Sat Mar 20, 2021 1:51 pm
You betcha! Covered in one of my other projects - https://www.synthmodes.com/modules/braids_renaissance/
Tboy
Post by Tboy » Mon Mar 22, 2021 11:13 am
Thanks Thomas, I had found that one, but i was referring to a more compact 'Bob Borries pdf' kinda cheat sheet. I guess that isn't available... Might just have a go at that.
Tboy
Post by Tboy » Tue Apr 06, 2021 9:48 am
Braids_Renaissance_cheat_sheet.pdf
(2.65 MiB) Downloaded 57 times
Ear it is, a 6 page cheat sheet for Braids Renaissance.
With thanks to Th0mas and Émilie !
deftinwulf
Post by deftinwulf » Tue Apr 06, 2021 12:06 pm
Braids_Renaissance_cheat_sheet.pdfEar it is, a 6 page cheat sheet for Braids Renaissance.
Hey, this is brilliant! Thanks for making and sharing! :yay: :love:
Jeez_Max
Post by Jeez_Max » Tue Apr 06, 2021 9:37 pm
Thanks for sharing the cheat sheet! I will get a lot out of this!
studio460
Post by studio460 » Tue Apr 06, 2021 9:41 pm
Holy shit! That's fantastic! THANKS!!!
