modules with 3.5mm TRS MIDI jacks
kay_k
Post by kay_k » Thu Sep 12, 2019 4:41 am
av500 wrote:here:
hahahahaha
you troll
Paranormal Patroler
Post by Paranormal Patroler » Thu Sep 12, 2019 5:45 am
TRS version works as a MIDI splitter though. :lol:
kay_k
Post by kay_k » Thu Sep 12, 2019 6:23 am
Paranormal Patroler wrote:TRS version works as a MIDI splitter though. :lol:
depending on the # and make of receivers tho
Paranormal Patroler
Post by Paranormal Patroler » Thu Sep 12, 2019 8:57 am
True. Your 2hp module is more than valuable, considering that it can also swap between the two formats and it takes almost zero space.
metamorphmuses
Post by metamorphmuses » Fri Oct 04, 2019 2:52 am
I recently bought a Polyend Poly 2 and just started using it. It comes with one MIDI DIN to 3.5 mm TRS adapter cable. I decided to buy a couple more, and went with cables meant for Make Noise 0-Coast. It turns out these are incompatible. I surmise that Make Noise uses Type A, i.e. the type Arturia uses, i.e. data maps to ring.
I contacted Polyend and promptly received a response; in fact, they sent me a diagram (see attached). Polyend uses the type in which data maps to tip, i.e. the type Korg uses, i.e. Type B.
Paranormal Patroler
Post by Paranormal Patroler » Fri Oct 04, 2019 3:44 am
I think MakeNoise uses the same type that Korg uses.
Compare http://www.makenoisemusic.com/content/m ... manual.pdf with Korg's little bits diagram from MIDI association https://www.midi.org/articles-old/updat ... din-cables
I'm fairly sure the one you're depicting above is the Korg type, and I'm also fairly certain Tony went with the Korg Type as we discussed this a long time ago when the 0 Coast first came out during a super booth, back when I was trying to get all manufacturers to adhere to the Korg Type (but failed miserably :hihi: )
kay_k
Post by kay_k » Fri Oct 04, 2019 3:06 pm
MN is most def Korg standard:
"connected using a simple TRS cable"
I've put down Polyend Poly 2 as Type Arturia (also according that pic) - please someone check my logic here cos I'm tired in the moment.
talkboxert
Post by talkboxert » Wed Nov 06, 2019 5:35 pm
The pocket operator modular 16 talks to my 0-coast that suddenly has a working midi interface. :banana: Thought somebody fried it in the euro coversion but seems hè just supplied me with type B cables. Sooooo much fun but I guess that’s One for the Korg/type a list
kay_k
Post by kay_k » Fri Nov 08, 2019 6:39 am
talkboxert wrote:The pocket operator modular 16 talks to my 0-coast that suddenly has a working midi interface. :banana: Thought somebody fried it in the euro coversion but seems hè just supplied me with type B cables. Sooooo much fun but I guess that’s One for the Korg/type a list
wait what .. that thing has MIDI ?
I HAVEN'T SEEN THAT, how awesome is this. I need one now!
[Edit:]
Korg is correct. They have the info in the online manual:
https://teenage.engineering/guides/po-modular/16
I find that super cool, still don't get why not all manufacturers publish this info.
tokidoki
Post by tokidoki » Thu Dec 12, 2019 8:14 pm
I hope this message is not out of subject.
Could you, please, edit the initial list according to the MIDI Association informations ?
It could help to clarify this ink bottle (bouteille à encre) topic.
If A is B and B is A we are in the 1984 world, confusion and despair.
Little confusion and very light despair I know, but we need lights.
Thank you for your work around this MIDI enigma.
kay_k
Post by kay_k » Fri Dec 13, 2019 6:37 am
Salut! C'est vrais!
:doh: corrected, thanks!
tokidoki wrote:I hope this message is not out of subject.
audionerd
Post by audionerd » Mon Dec 16, 2019 2:51 pm
vector sequencer is type b. confirmed with five12 via email.
kay_k
Post by kay_k » Mon Dec 16, 2019 4:12 pm
audionerd wrote:vector sequencer is type b. confirmed with five12 via email.
thanks
audionerd
Post by audionerd » Thu Dec 19, 2019 6:47 am
thanks for all your work on this data!
i've started to organize structured data from this thread, along with data from my own research, and made it public domain at:
https://github.com/audionerd/minimidi-data
i'll try to keep it up-to-date with this thread, but PR's are welcome, too.
also, using that dataset, i'm working on a microsite to better explain how TRS MIDI works, and to help people search for MIDI TRS type by device:
https://minimidi.world
kay_k
Post by kay_k » Thu Dec 19, 2019 7:24 am
:yay: :nana:
[also.. could you please modify my vendor name to LPZW.modules otherwise ppl will probably not find me in that list]
audionerd
Post by audionerd » Thu Dec 19, 2019 9:07 am
sure! done.
kay_k
Re: modules with 3.5mm TRS MIDI jacks
Post by kay_k » Mon Dec 23, 2019 7:46 am
the transition to the new software omitted the last entries to this thread. I can't find the URL to that MINIMIDI website that was so nicely done.
morgulbee
Post by morgulbee » Tue Dec 24, 2019 12:15 am
Here it is: https://minimidi.world/
A great resource for TRS MIDI information.
mamonu
90s ambient miscreant!!
Post by mamonu » Tue Dec 24, 2019 4:29 am
my case (Dreadbox 168) has midi inputs in TRS format. http://www.dreadbox-fx.com/modular-cases/
I dont know what standard it follows but I would guess its KORG as someone mentioned a dreadbox module that used that...
frac & 100m & eurorack (equal opportunities wiggler)
:blacet: :blacet: fracmodular.github.io :blacet: :blacet:
tokidoki
Post by tokidoki » Fri Apr 03, 2020 1:47 pm
Just received from Germany a FLAME QMCV - MIDI to 4 CV-Gate-Velocity Interface.
For the list :
MIDI Input (MIDI TRS-B Standard)
MIDI THRU Output (MIDI TRS-B Standard)
Thanx.
RecycleYourPets
Post by RecycleYourPets » Wed Jul 15, 2020 7:46 am
Just got confirmation that the Division Department 01/IV drum machine uses the Type B trs midi.
(to copy the previous posts format:
https://www.thedivisiondepartment.com/pages/01-iv
Schenk.work - instagram.com/schenk.work
MikeLeeBirds
Post by MikeLeeBirds » Wed Nov 18, 2020 10:33 am
Thanx.
How is the QMCV working for you? The voltages on mine are slightly off and I‘m waiting for information on how to calibrate it.
dooj88
Post by dooj88 » Wed Nov 18, 2020 10:47 am
oh F ME.. lol, why or why didn't i know about this thread the last few weeks after ordering 2 of the wrong midi adapters for my performer. i've been banging my head against the wall thinking my unit was busted.. actually today i was going to order a type a, but confidence was very low. glad to get confirmation i'm not doing something wrong (aside from wasting money).
MikeLeeBirds
Post by MikeLeeBirds » Wed Nov 18, 2020 2:10 pm
I had a version of the Performer where you could switch TRS types.
dooj88
Post by dooj88 » Wed Nov 18, 2020 2:14 pm
definitely not something mine is capable of. i think my board is a rev done by MSW, not sure if that had any impact on the midi standard it needs, but yeah type B - the one 1010music sells, and the one on amazon for $6.99 (that doesn't specify a standard :doh: ) did not work. just ordered the korg/type A, fingers and toes crossed. i really wanna play with the arp settings on this thing (while my keystep is arping!)
