I have the Volca Bass, and I can indeed get it to reset, but:paul_exp wrote:Was referring to reset on transport start, so when I hit play on external sync source, the volca starts from step 1 (unless I've missed something? I've not found a way to do that yet...)oscillateur wrote:What do you mean ? You can reset patterns on the Volcas.paul_exp wrote:Epic! Does your mod allow pattern reset? It's the thing I sorely miss on my volca...
Anyway, trigger outs are just what I'd be looking for on mine but this looks pretty cool.
1. Don't use it as the master. It always outputs the clock signal, whether play is pressed or not. I don't know if they fixed this on the Sample.
2. Reset your main clock source. Then press play on the Volca. It should sync, and the sequencer won't start until you start your main sequencer. It'll start from the top of the pattern. {I would imagine this works the same way on the Beats, if it doesn't, oh well}
3. Don't change patterns on the Volca while the sequencer is running, because it'll start from the nearest 1/8th (or maybe 1/16th?) beat, and it's too hard to be that precise to push the buttons at the right time. I know, kind of sucks.
Maybe they can fix this in a firmware update?
