Intellijel Quadrax
scottmfr
Re: Intellijel Quadrax
Post by scottmfr » Mon Apr 19, 2021 11:21 am
The only button combo I think you really have to remember is to press and hold the top left and bottom right buttons to clear all assignments. I usually do this when I'm starting a new patch and make the assignments as I go to make it easier to keep track of what's going on.
ferran
Post by ferran » Mon Apr 19, 2021 11:28 am
That's right, I do this very often :hihi:
studio460
Post by studio460 » Mon Apr 19, 2021 12:20 pm
Ha! Finally read the whole manual. I read it when I first bought it but I guess it didn't take. Now I totally get it. I think I just forgot what the first knob did and was probably unknowingly chaining the crap out of everything. Can't wait to use my "new" module! My only question is: How do you tell which mode you're in? Default or alternate? (I'm not at home right now.)
Jopy
Post by Jopy » Mon Apr 19, 2021 12:59 pm
The mode LED (on the right) will flash.
studio460
Post by studio460 » Mon Apr 19, 2021 7:12 pm
Awesome! Thanks!
Dcramer
Post by Dcramer » Mon Apr 19, 2021 7:46 pm
kisielk wrote:
Sun Feb 21, 2021 7:43 pm
@Dcramer technically it's possible but I'm not sure about the UI. Right now it relies on brightness, which is not great already, if there were 5 or 6 levels it might be too difficult to tell them apart? Will think about it, or if you have any suggestions ...
I’ve been using mine lots and thinking about a simple way to denote/display more attentuator levels;
I’m thinking that when setting CV levels it shows you a dimming LED colour and then a different dimming colour for inverted, so why not just use all four colours? Two for positive modulation and two for negative modulation, each colour would still have the same few dimming stages so they’re easy to recognize but you’d get twice the number of attenuation steps! :sb: :sb: :sb:
And regarding the CV matrix, I am literally ‘the dumb’ like the man that brains forgot, my big worry with Quadrax was never being able to remember how to set the CVs. All I need to do is remember the difference between the long button press (magenta) and the short press for the left hand row. And then I’m golden, it’s simple and really worthwhile because it’s so flexible; you can have only one or two CVs patched in but have them bussed all over the place doing different things :hail:
DJ Tap Water
Post by DJ Tap Water » Thu May 06, 2021 4:02 pm
Does anyone know what the latency of quadrax is?
Dcramer
Post by Dcramer » Thu May 06, 2021 10:47 pm
Latency as in how long does it take to fire when it gets a trigger?
kisielk
Post by kisielk » Thu May 06, 2021 11:03 pm
Less than 1ms in the current firmware
Intellijel R&D
efluon
Post by efluon » Fri May 07, 2021 4:21 am
I hope it is less. Got mine only very recently, will have to verify. But you know what you are talking about, right?
ima_jrk
Post by ima_jrk » Fri May 07, 2021 6:34 am
Given that they work for Intellijel, I would take the answer as authoritative.
ferran
Post by ferran » Fri May 07, 2021 9:52 am
:yay:
Neo
Post by Neo » Sat May 08, 2021 5:18 am
Quadrax can be complicated but it doesn't have to be. I just leave mine as 4 envelope generators with CV over decay. Sometimes change modes between AD and ASR, and that's it, it's exactly what I wanted, nothing more, nothing less, nothing to remember
makesilence
Post by makesilence » Sat May 08, 2021 11:46 am
I don't own one yet but what do people find complicated about it? I was watching video tutorials and it seemed somewhat straightforward.
borg029un03
Post by borg029un03 » Sat May 08, 2021 11:57 am
I like the Quadrax, but in my opinion the other Modes the AD and ASR are very unintuitive. Can't use without Manual.
An Attanuator Expansion would be cool.
Industrial Techno Template for the Analog Rytm:
https://gum.co/wSHfG
Analog Rytm Techno Preset Pack:
https://gum.co/ERTPbMB
modularbeat
Post by modularbeat » Sat May 08, 2021 2:34 pm
The process for programming the modulation matrix can feel a little complicated- I was occasionally confused until I realized that the blue LED on the left side corresponds to the blue labels for CV inputs A,B,C,D.
While it would have been more intuitive (to me) to select the modulation source, then the destination channel, then the destination parameter, I understand that the intent is probably to work on one channel at a time (select channel, then modulation source, then parameter).
But, yeah, short of making the module huge or adding a display and menu system, I don’t think Quadrax could be made much less complicated without removing features. It’s damn near the perfect module for my purposes.
